how do you delete an imported part from an imported assembly?
https://cad.onshape.com/documents/4a78f7e755a5111dd4258e3f/w/df3dcaedda26a1061a45278e/e/949141c24188f8c8721ce828
  • glen_dewsburyglen_dewsbury Member Posts: 1,098 PRO
    Select the part in assembly then hit the delete key is about the simplest way.
    BTW your link is not public and can't be opened by others.
