Problem with Surface text Cut out function
thomas_franssonthomas_fransson Member Posts: 5
Hi everyone,
I’m encountering an issue with the Surface Text feature in Onshape. Everything works fine when I create the text, but as soon as I try to use the Cut Out command, it doesn’t seem to function as expected.
Has anyone else experienced this issue? Any suggestions or solutions would be greatly appreciated.
Link to the projekt https://cad.onshape.com/documents/ea5b74ca6bc648d8d47237fc/w/f9566770f41aba31000a90bb/e/639ccefb2e471db4ce49080c?renderMode=0&uiState=678c16372df6b315c5070925
Thanks in advance!
