How can i do this sweep
maurice_rietveldmaurice_rietveld Member Posts: 13
Hi All!
Bit new to onshape but what a nice program :D i just wanna make this piece for my childeren, this one is made in Tinkercad..
But how can i made this kind of sweep?
It needs to go in a T where the end also needs to go down.. Im lost search the internet on google but no succes xD and i know it needs to be possible :P
Thanks!
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 352 image
    This is likely going to involve a Loft. There are a lot of controls (guides, paths, end conditions, etc) to experiment with, but our docs and other learning resources should point you in the right direction.
  • MDesignMDesign Member Posts: 1,133 PRO
    Probably not the easiest way to start learning Onshape. But it can be done one way or another. Hard to say which way is best with just one obscured view. Might I suggest exporting from tinkercad in a format that can be read by Onshape? Not familiar with tinkercad export options. Just doesn’t make sense to reinvent the wheel if you don’t have to.
  • jelte_steur814jelte_steur814 Member Posts: 531 PRO
    these could also just be two cylindrical cuts with a big blend in between. hard to tell from just this picture.
    you could import the tinkercad model and share your trials on this thread to get some more detailed help (share the document publicly)
  • maurice_rietveldmaurice_rietveld Member Posts: 13
    im lost haha xD try all different things but frustrates me haha
    how can i share that one it is in a document with a lot more things in there haha xD
    or do i need to share the hole document?
  • wayne_sauderwayne_sauder Member, csevp Posts: 622 PRO
    @maurice_rietveld
    Create a duplicate of that part studio, then move the duplicate studio to its own document and share that document.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 766 PRO
    https://cad.onshape.com/documents/7b265f9547ea96d0c8af0858/w/a086dde488156e48d7b16a86/e/3892bbe4dfe3de7f50dfe965
