hey is it possible to get my pipe round and symmetric instead of the shape of a egg?
carl_dahlgren
Member Posts: 12 ✭
in General
hey im wondering if it possible to make my pipe round instead of the shape of a egg?
https://cad.onshape.com/documents/6bb5f0683ce47e2346f6e7b3/w/930af4f057839b1e5dbdaa34/e/ea3954fea9e5189b759784e0
hey yes. but as you can see, the intersection of a cylinder and a flat face will be an egg if the two are not orhogonal. so, you'll want to angle your original circle for extruding.
https://cad.onshape.com/documents/7b265f9547ea96d0c8af0858/w/a086dde488156e48d7b16a86/e/eefcb9c08b580f6484a247e9
If you sweep a circle at an angle, you get an ellipse by definition. What exactly do you want?
Don't use the hole as the basis for the tube. Start by creating a "curve point" plane, on the end of the angled line. sketch a circle on this new plane, then extrude the circle "up to face" on the base plate.
As a 2nd option - (maybe a better way) you can also use the "frame" command.
Also you don't need separate sketches for the small holes - put them all in the 1st sketch (and use dimensions, until sketch is "resolved").
I strongly recommend that you take the "self-paced learning courses" in the learning center. Most of the entry level courses are free, and do a very good job of explaining how to get started "step by step".
Good luck
thank you! how do i angle the cirkle sketch?
Thank you guys! :)
