Part Studio
göte_berggren
Member Posts: 5 ✭✭
How to remove a part including it's associated sketses and features from a part studio?
Have difficulty to figure this out!
Removing a part by deleting it will always retain the sketches: Something else might be built on these, too! If you want to remove all of it, you'll need to start with the earliest element that was used to build the part (in most cases the sketch) and delete that. Then all other features built upon that will become invalid and turn red in the tree. Delete these, too. BUT BE AWARE that this will kill all other parts sharing the same features! That is why they are not deleted the usual way.
