Render Studio Custom Appearances
Stuart_Wood_01
Member, csevp Posts: 9 ✭
I'm really liking the recently improved Render Studio, i'm finding it much more user friendly and intuative.
I do however have an issue with appearances. I don't appear to be able to save my own appearances to my Company Favourites.
This isn't such a problem for the current document i'm working with but it does mean that any Custom Appearances are not ported across to other documents which require the same Custom Appearance.
Have I missed something or will this be an improvement request ?
I look forward to hearing your thoughts.
eric_pesty
Member, pcbaevp Posts: 2,528 PRO
You can now "import" appearances from another render studio. I've created a document in my "admin files" with some render studios where I import appearances for later re-use.
Not as "clean" as a real library system but it works reasonably well to save and retrieve appearances as you can a pick and chose which ones to import between studios.3
I agree, it has come a long way! It's feeling more and more Onshape. They also really increased the performance so that it's pretty user friendly now.
There are still a few things like this that make it painful to use. I should probably go make some IR's for these. Don't really want to bombard the Onshape team with theses atm, but may upload them soon.
Great idea as a work around until a library system (hopefully) gets implemented.
Thanks for the tip.
These are all really valid suggestions for improvements and would certainly improve the quality of life in Render Studio.
