Hole to Slot (new featurescript)
jelte_steur814jelte_steur814 Member Posts: 543 PRO
Hi,
I often create slot holes based off the hole feature. I see questions about slot holes regularly so I figured it would be a good practice case for a new feature script.
So here goes. please let me know if you come across bugs, improvement possibilities and edge cases that aren't handled well.
hole to slot feature
  • eric_pestyeric_pesty Member Posts: 2,410 PRO
    That's a neat idea!
    Also means if you have a design with a hole you can convert it to a slot later without sketching.
  • S1monS1mon Member Posts: 3,660 PRO
    Very cool.
    It looks like "direction" doesn't support implicit mate connectors. Any reason not to have that option?
  • EvanReeseEvanReese Member, Mentor Posts: 2,619 PRO
    yes! I've wanted to make this but your implementation looks fantastic.
    I agree with Simon about mate connectors being handy for the direction.
    It could also be nice to be able to pick multiple holes, at least for the straight option. It seems like just adding a forEachEntity() to the SLOT_TYPE.STRAIGHT would do it. You may wanna pre-process the selection so you don't get duplicate holes if there's more than one face picked in a hole. You could set up two hole face query params that look the same so the curved version can still be limited to 1 selection.
    (or you may not want to do this at all haha)
  • martin_kopplowmartin_kopplow Member Posts: 1,019 PRO
    Yes, great! I've been missing that one already. When I was working with Spaceclaim, they had a very similar one, and I used it a lot. You would just drag a hole along a curve and that simply created a slot.
    Thank you very much. Good job!
  • jelte_steur814jelte_steur814 Member Posts: 543 PRO
    edited February 7
    thanks for the feedback and suggestions.
    @S1mon, I was using the standard QueryFilterCompound.ALLOWS_DIRECTION, which doesn't include the mate connector, so I added that. It makes it a lot easier to create an angled slot, so it's a significant improvement.
    BTW I found that the accompanying 'extractDirection' immediately processed the mateconnector as expected.
    @ilya_baran: could the queryFilterCompound.ALLOWS_DIRECTION be updated to include bodytype.mateconnector?
    I also found out the underlying operations don't support active sheet metal parts, so I disabled selections there.
    so these are improvements included in V6
    @EvanReese Multiple holes is indeed a neat idea. the pre-processing and the forEachEntity will be bit more work though.
    @ilya_baran , @EvanReese . see post above. the @links stopped working halfway the post.
  • romeograhamromeograham Member, csevp Posts: 719 PRO
    I like this functionality too! I'll give it a try and provide feedback / comments as I run into things.
    Update:
    V8 allows multiple hole faces for the straight slots. Just make sure you only select one face for each hole.
    The disambiguation of multiple faces into one hole face to be processed is a challenge still ahead of me. Any suggestions how to approach that?
    There may be a better way but a check could be isQueryEmpty(context, qSubtraction(q1, q2))
    You may need to first subtract the active query from the main query, then test this.
    edited February 7
    thanks @EvanReese. I figured it out. perhaps there's a smarter/quicker way, but this works:
    in V9 drag selection multiple faces for one hole can be selected so drag selection is enabled
    nice!
