Complete beginner
Hello everyone,
I'm a complete beginner and I'm following a youtube series, however I'm unable to even go pass the first step, which seems to be the "defines".
Below is the very simple model, which i can't define the top and bottom lines. Could anyone help?
https://cad.onshape.com/documents/a68e02c1ae89d238c8361bf5/w/16de69dcb838a699876053d0/e/e643a926f6799221e000fb3f?renderMode=0&uiState=67ab155f03bacf5cb77adb57
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,060 PRO
    edited February 2025 Answer ✓
    Use the symmetric constraint to make the top and bottom lines of the rectangle symmetric about the front plane.
    The tutorial you followed "probably" used the center-point rectangle, and aligned the center point with the origin. Right now you have the tangent of one of the circles aligned with the origin.
    Also your circles are all construction lines. If you want to make a board with holes, change them to solid lines. Click the circle and press the Q key to do that.
