Customizing the names of parts generated by patterns
sasha_sklar061
Member Posts: 14 ✭
I've yet to dip my toes into FeatureScript but this might be the problem that makes me jump in if it's solvable. Does the API give you access to control the names of parts generated by a custom feature?
Caden_Armstrong
Member Posts: 344 PRO
you can set the names of parts in featurescript with the setProperty function.
yes, the API can name parts, but in most use cases a featurescript is going to be easier.
www.smartbenchsoftware.com --- fs.place --- Renaissance
Custom FeatureScript and Onshape Integrated Applications0
