Thicken failure
graham_lockgraham_lock Member Posts: 262 PRO
Hi,
This relates to a model aircraft turtle deck.
Can anyone advise why the thicken in this document fails please?
I need the thicken to work inwardly, it currently only works outwardly.
https://cad.onshape.com/documents/fe80892a600c8d5a25408745/w/c6a7d33eb9629d4740decbf1/e/3e14da01e17f513433dd1023
Thank you.
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 367 image
    edited February 13 Answer ✓
    Zoom right in on the end of the spline in that sketch
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 843 PRO
    There is some crazy curvature at the top edge.
  • graham_lockgraham_lock Member Posts: 262 PRO
    Thank you - could you send a screenshot of the curve / surface analysis options you used please? I can't seem to replicate what you saw.
    edited February 13
    Take a look at the sketch called Former D…
    Specifically the direction of the curve at the left (as seen above) end. It is going in the wrong direction…
    Next, the Skin turtle decks 2 (Loft feature) should be made tangent to the previous loft. Currently there is a non-zero dihedral angle.
    Do the same for the Skin turtle decks 3 feature (make the start profile condition tangent to the edge of previous Loft)
    Now it will thicken with 2.1 mm. Any thicker than this towards the inside direction will fail as the curvature is too tight. Onshape has great diagnostics for all of these above issues mentioned, including this last one
    Thank you.
    I understand the start profile tangency requirements but I'm not sure what you mean by former D curve is going in the wrong direction?
    Yes!
    Thank you.
