JT Export
laurent_diazlaurent_diaz Member Posts: 1
Hello there,
I am just starting with onshape and I am very impressed!
Ohshape can already import JT files, do you have any plan to export to JT?
That's an important requirement for my projects.
Thanks,
Laurent
  • andrew_spaldingandrew_spalding Member Posts: 3
    In support of laurent_diaz's request: JT may or may not be technically better than the formats already supported, but many Siemens applications (which we use extensively) only support JT, and the ability to create these in OnShape would be a huge advantage.
  • john_rousseaujohn_rousseau Member, Onshape Employees, Developers Posts: 409
    Hi @andrew_spalding. We have heard multiple professional users request JT export support. We are looking into supporting this in the future. Often JT import/export is customized for a specific company or workflow. Would you be willing to tell us more about your use case?
    Thanks
    -John
