need help with surfaces
james_ottojames_otto Member Posts: 2
https://cad.onshape.com/documents/ebfc3bfaf5b4c1b431c49dab/w/654dd1c447fb6e05280122d6/e/969cdb6fba0c9104551064c3 in my doc linked here i am trying to make thes 2 surfaces thicker to make 3d printing easier how can i make a shcech or can i extrude
  • MDesignMDesign Member Posts: 1,260 PRO
    Your surfaces are imported mesh files and will not play nice with the surfacing/modeling tools. They also have holes in them shown here. You will have to recreate the surfaces using the mesh mesh as a guide for onshape tools. Or you could edit the mesh in another software. Not the easiest to learn surfacing on that particular set of surfaces. learn.onshape.com has some great tutorials to get you started
    edited February 17
    I was feeling ambitious and fixed your STL file. It is now a watertight model that can be 3D printed as is or edited with onshape tools like extrude cut/add. but not tools like thicken.
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,034 PRO
    Not going to happen in most mechanical CAD software. Plus, the stl is pretty bad. Besides the missing surfaces as MDesign mentioned above, it's very coarse, and will look bad after printing. Best bet IMO is to try to find the original author and see if they have a STEP file they can share. Or, one of the mesh softwares might be able to do it (I've never used any, so can't recommend one).
  • martin_kopplowmartin_kopplow Member Posts: 1,077 PRO
    edited February 17
    That looks like the motorcycle front fender excercise I've seen in CAD training courses. There should be real surface models of this out there. Else, it is still a good exercise for surface modeling, also for Onshape users.
    (BTW.: The scale of the model appears to be all wrong.)
