No pdf's in .zip when batch exporting drawings
leon_tulling
Member Posts: 12 PRO
in Drawings
Hi,
I want to export a fairly amount of drawings (approx 60 drawings) at once, and with the batch export option this should be easy. But when I'm exporting the drawings, Most of the drawings don't appear in the .zip file. I tried to narrow it down to about 10 per batch, makes no difference. I can export the drawings one-by-one, so the PDF's are fine?
Can anyone point me in the right direction of where to look what the problem can be?
Thanx!
Creative Technician Mechatronics | Freelance Engineer
www.leontulling.nl
www.leontulling.nl
I would just submit a ticket for something like this…
Good point! I'll try that…
I was just hoping on a known issue with an easy fix… 😉
www.leontulling.nl
