No pdf's in .zip when batch exporting drawings
leon_tullingleon_tulling Member Posts: 12 PRO
Hi,
I want to export a fairly amount of drawings (approx 60 drawings) at once, and with the batch export option this should be easy. But when I'm exporting the drawings, Most of the drawings don't appear in the .zip file. I tried to narrow it down to about 10 per batch, makes no difference. I can export the drawings one-by-one, so the PDF's are fine?
Can anyone point me in the right direction of where to look what the problem can be?
Thanx!
Creative Technician Mechatronics | Freelance Engineer
www.leontulling.nl
  • eric_pestyeric_pesty Member Posts: 2,275 PRO
    I would just submit a ticket for something like this…
  • leon_tullingleon_tulling Member Posts: 12 PRO
    Good point! I'll try that…
    I was just hoping on a known issue with an easy fix… 😉
    www.leontulling.nl
