opCreateCurvesOnFace() for parameters 0 and 1 fail?
EvanReeseEvanReese Member, Mentor Posts: 2,695 PRO
Even the native Isoparametric Curve feature can't do a parameter of 0 or 1 on a periodic surface (for example: to get the circular end of a cylinder). Does anyone know a decent workaround?
  • EvanReeseEvanReese Member, Mentor Posts: 2,695 PRO
    Thanks fellas. Here's what I ended up coming up with. Since my case is somewhat narrow I don't have to worry about dealing with trimmed surfaces and I know that the only 2 edges a periodic surface will have are the ones I need.
    function getEdgesOfPeriodicSurface(context is Context, face is Query) returns array
    var paramPoints = evFaceTangentPlanes(context, {
            "face" : face,
            "parameters" : [vector(0, 0), vector(1, 1)]
    return [qContainsPoint(edges, paramPoints[0].origin), qContainsPoint(edges, paramPoints[1].origin)];
  • S1monS1mon Member Posts: 3,777 PRO
    A guess: split the cylinder in halves, and create two curves?
  • MichaelPascoeMichaelPascoe Member Posts: 2,689 PRO
    edited February 20
    Could you use evFacePeriodicity and evApproximateBSplineSurface to get the underlying surface then get get the curve from that?
            "face" : face,
