Change part ID to be the same for all configurations
Nick_HolzemNick_Holzem Member Posts: 152 PRO
In my model I am configuring a composite curve and then referencing the endpoint of the curve with a sketch. The selections of the composite curve are different in 2 configurations, so the sketch constrain (coincident) loses its reference. Is there a way to over-ride the part ID so that the sketch won't lose its reference? I've been trying other features as work arounds but I can't find a solution that will keep its reference. Is the part ID the right way to look at this or is a solution not possible?
