Not a 90 degree angle
What do I have to do so that the 2 surfaces fit together at an angle? (like the red line)
martin_kopplow Member Posts: 875 PRO
Create an intersection line at the rear, then use that and one corner on the front to create a plane (like red line), trim both parts to plane.
https://cad.onshape.com/documents/dad8fe22fdd4755011f97cfc/w/7a65781335fe3f3c0b2258fc/e/786df19f5f86fb065374c6fc?renderMode=0&uiState=67b8d82a340eaf35295b1f15
Either do it as one sketch, one extrude, or use boolean to join them together.
If they need to be separate parts then your sketches need to represent that angle. or you need to apply draft angles to each piece or a more complicated method possibly
A sample from MDesign's comment. Quite simple. Angle set in sketch.
https://cad.onshape.com/documents/1d35f627efed69ade1b185a2/w/3713e0d14bfcfe62f90cebb8/e/ad47bc6f19df380153983c5e
Danke
