Is there a way to add a revision symbol to the second sheet?
eric_pestyeric_pesty Member, pcbaevp Posts: 2,474 PRO
edited March 2022 in Drawings
I feel like I might be missing something here but I can right click on the revision table to add a revision symbol on the first sheet but when I go to another sheet I don't have that option because it just says "See sheet 1"...
Copy/paste the symbol from sheet1 doesn't work either...
EDIT: never mind, I figured it out a workaround! Just temporarily change the revision table to "linked" and then you can get the option to right click and then change it back to "See sheet1". That's kind of convoluted though and feels like a workaround...
  • ry_gbry_gb Member, csevp, pcbaevp Posts: 110 PRO
    I just ran into the same problem and came across your solution. Thanks for documenting it. Seems like a cumbersome workaround, but at least you can do it…
    Ramon Yip | glassboard.com
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,474 PRO
    edited February 21
    @ry_gb
    Actually I never came back and edited this but you can just right-click in the background of the sheet and select "add revision symbol"…
