Lofting 2 elipses around a curve.
I found this on one of Too Tall Toby's YT videos - it had no video for it, but I wanted to do it anyway; furthering the development f my skills. I was trying a Loft, but encountered an error that I couldn't resolve.
"Curved Alignment Post" — Colin King
  • Use the the "guides and continuity and add the circular "paths".
    Note that if you search public documents for "24-08-17" you will find lots of examples of how to solve this part, for example:
    https://cad.onshape.com/documents/c23d648561898b455a24676b/w/a48306a194dd22ebf52e7cd3/e/257a793b872789dc900f95b2
  • I have tried several ways (your suggestion first) east of Sunday and I have fail all times. I was annoyed so much I deleted the entire file. I decided to send a message directly to TTT regarding this and then begin again on a clean slate. Thank you for your response; must have been an error previously with creating the geometry.
  • Thank you for your response! —- I tried several methods - your suggestion 1st. After searching the responses to the errors and getting more confused I felt that it was best to totally delete the file and start afresh. I sent a message to TTT (through his website) regarding this project and await a favorable reply.
  • You have to make sure your guide curves are actually "piercing" the profiles, which is clearly not the case at the bottom left in the first picture above.
  • That was one of the procedures to try and it didn't work; actually I threw in the towel. Oh well. It is only a practice exercise, one that I figured be interesting, will revisit it another day. Thanks for the follow-up.
    Stay Creative,
  • john_lopez363
    john_lopez363 ✭✭✭
    edited February 2025
    @colin_king506 … keep practicing… you'll get it. As previously stated the basic issue is your Loft is not precisely defined, there are several important constraints that must be correct for this to work. You can follow along in the link below. Pay close attention to the constraint, specifically around the ellipses and guide curves used for the Loft.
    https://cad.onshape.com/documents/e32a90281dc561cf3f5462dd/w/3df15d13eb3a662cb71af2d3/e/a1b850d31e44fc8e5ebee61d
  • Thank you John. I have begun the part again paying particular attention… as you stated… to constraints; etc. I am not going to forego looking at what you have done at this time, I am going to see if I can derive this on my own first.
    For whatever reason this was giving me fits and I had to separate myself from it, do something else and return with a new perspective,
  • I give up!!!!!!!!!!!!!!!!!! Can you recommend some practice exercises that deal with Lofts around curve.
  • john_lopez363
    john_lopez363 ✭✭✭
    @colin_king506 …https://learn.onshape.com/learn/learning-path/onshape-fundamentals
    Take the training offered by OnShape. It's appears to me that you are missing some of the basic fundamental principles. This is the best way to learn OnShape sans an actual in classroom course.
  • Every other project I go back and try again. I did follow some Onshape training videos and saw my mistake(s) and adjusted accordingly, I was able to successfully complete the loft on a curve using the spline command. Did not try a curve, but I would assume (your mileage may vary with that word) work similarly.
  • I figured it out this afternoon.
