Curved surface being split into facets on export, is there a workaround?
Member Posts: 11
Hey Folks,
When working on a simple train cab roof I've run into a little issue I've not seen before. I set a curve to the radius required to sit up against the cab wall, and then offset this to create the thickness of the roof. Now when I'm exporting to print as an STL files (Lychee slicer wont accept SETP or Obj files) the curve of the roof is heavily faceted.
Ive done a serach and see this has come up before as an issue, so wondering is there a process in my workflow i should be doing to get these outside smooth surfaces?
https://cad.onshape.com/documents/6d936a4258749c01da774eb2/w/c1ea534a2514a84b38194db5/e/f1f3ad4a960a92ea8cef213c?renderMode=0&uiState=67bb4c7bd2ffce22089e11ab
