Unable to Boolean Substract After Deriving a Part
artem_adylinartem_adylin Member Posts: 2 EDU
I am trying to make a mold or something that the chess pieces will go into to not wobbly while being transported. Unfortunately I encountered an error with boolean modifier and I cannot seem to do it. It shows 2 points on each knight when I try to boolean it. I have tried to boolean simmilarly in the part studio where the knight was made and it works perfectly fine. I cannot figure out what I am missing. Side note I am fairly new to onshape.
https://cad.onshape.com/documents/c4fd1964633190125c57f3f2/w/535a790c5fad12b6b37bfafb/e/3abaf3cf9ccade5bffd2e191?renderMode=0&uiState=67be1f4371b86a169c2c6572
The part should be in the Chess Board part studio and it should be the part 15 and the last few modifiers.
Any help will be appreciated. Thanks!
  • S1monS1mon Member Posts: 3,985 PRO
    Seems like you solved your problem.
