3D Printing Error
theekshi_gajendrantheekshi_gajendran Member Posts: 5
So, I made my model of the eiffel tower and everything on onshape was fine. I exported as a DXF and onto Bamboo Lab to print, but then i tried slicing plate but it didnt work. It said that there was error with the boolean operation. I did encounter this error before but when i used the circular pattern for my extrude remove, the error was fixed. Is there anything I can do to successfully 3D print this?
  • _anton_anton Member, Onshape Employees Posts: 480
    Probably because of the DXF export. Try STL or OBJ? I don't remember if Bambu slicer supports native CAD formats.
  • S1monS1mon Member Posts: 3,456 PRO
    Bambu supports STEP. I would start there.
  • theekshi_gajendrantheekshi_gajendran Member Posts: 5
    Wait, I did export as STL, I think the main issue was with Boolean operator, although this only came during the 3D printing process and not on Onshape
  • martin_kopplowmartin_kopplow Member Posts: 846 PRO
    There should not be any booleans involved on the slicing level, if you exported but a single body. So, this raises a suspicion you might have exported multiple bodies that overlap.
