Repeat the function's action for each selection of the UI
ben_partouchben_partouch Member, csevp Posts: 158 PRO
edited February 18 in FeatureScript
I have a simple function to split face using a text. I want to be able to select multiple faces and have the function executed for all of them.
How do I go about it?
Thank you
    // Define the function's action
    var center = evPlane(context, {
            "face" : definition.faceToSplit
    debug(context, center, DebugColor.RED);
    var sketch2 = newSketchOnPlane(context, id + "sketch2", {
            "sketchPlane" : center
    var text = skText(sketch2, "text1", {
            "text" : definition.text,
            "fontName" : "Poppins-Regular.ttf",
            "firstCorner" : vector(0, 0) * inch,
            "secondCorner" : vector((1 * inch), definition.fontSize)
    skSolve(sketch2);
    var textEdges = qSketchRegion(id + "sketch2");
    var loop = qLoopEdges(textEdges);
    debug(context, loop, DebugColor.GREEN);
    opSplitFace(context, id + "splitFace1", {
                "faceTargets" : definition.faceToSplit,
                "edgeTools" : loop
    opDeleteBodies(context, id + "deleteBodies2", {
                "entities" : qCreatedBy(id + "sketch2", EntityType.EDGE)
  • Jed_YeiserJed_Yeiser Member Posts: 56 PRO
    edited February 18
    I'd recommend looking into using a for loop here - though you may run into challenges for any non-planar face as your code requires a planar face to create a plane which you then sketch on. I'd imagine that WHERE you want to split each face is a fairly specific location and that simply solving for 'a plane' on that face does not get you the resolution you're looking for. I'd recommend something similar to what follows:
    1. Create a Mate connector somewhere (the origin? why not. Doing so makes things easy).
    2. Figure out how many faces you have
    3. For each face:
      1. create a mate connector on the face at the location you'd like to move the sketch edges to
      2. (copy?) transform the of the reference sketch to the new location defined by the mate connector.
      3. split the face as you've done.
    Cheers,
    -j
  • jelte_steur_infojelte_steur_info Member Posts: 605 PRO
    try putting the above in a 'forEachEntity'
    https://cad.onshape.com/documents/37fa98fdc1a0b9ce78ff38bb/w/257085d868fb32e6998b6a89/e/11361fdeab998371aea29978
  • ben_partouchben_partouch Member, csevp Posts: 158 PRO
    Thank you @jelte_steur814 , @Jed_Yeiser
    I tried this but it didn't work: (It worked for the first MC selected but not the next ones)
        forEachEntity(context, id + "operation", definition.locations, function(entity is Query, id is Id)
                // perform operations with the entity
                        "face" : definition.locations
                var sketch1 = newSketchOnPlane(context, id + "sketch1", {
                var index = skCircle(sketch1, "circle1", {
                        "center" : vector(0, -26) * millimeter,
                        "radius" : 0.25 * inch
                skSolve(sketch1);
                var markerEdges = qSketchRegion(id + "sketch1");
                var loop = qLoopEdges(markerEdges);
                            "edgeTools" : loop
                            "entities" : qCreatedBy(id + "sketch1", EntityType.EDGE)
    edited March 3
    forEachEntity applies the function to each instance of definition.locations by passing one of those instances into the 'entity' in the function.
    you could rename 'entity' to 'location' for clarity's sake and understand that your definition.locations in the var center = evPlane(…
    should be replaced by 'entity'/'location' so it will do one at a time.
    BTW. I've found that although AI doesn't understand Featurescript well, it does understand basic programming better than I do (because it's seen a lot more code) and can help out with questions like these that are not very onshape/featurescript specific, but more programming logic.
    Thanks a lot @jelte_steur814 .
    Used both your tips. ChatGPT got the first time.
