Can't subtract two parts
angel_hernandez326
Member Posts: 8 ✭
Hello,
I seem to keep running into this issue and never really figure it out… even after googling it, so I always build crappy workaround to solve it and I'm sure there is something I'm just missing. Can anyone help?
Here is a link to my document: https://cad.onshape.com/documents/d1da93a1497d672f4bd5d0c2/w/3f1bdf132bebb70841bf45eb/e/fe452418000da36dc9af8584?renderMode=0&uiState=67c4991cf242694bd8393bce
There are two parts I am trying to subtract with a little offset of 0.2mm in all faces. It all fails when I select offset all regardless of the distance and direction:
Can anyone tell me what I'm doing wrong?
Thank you!!!
GregBrown
Member, Onshape Employees, csevp, pcbaevp Posts: 381
See response to your other question
Sorry for the double post.
Thank you for your help! That solved the problem :)
Link to your solution here:
