Can someone help me fix this model? It is simple - yet very broken.
david_no_thanksdavid_no_thanks Member Posts: 8 ✭✭
Hi all,
I made this slingshot model a while back. It is heavily inspired by another's design called the Bean Flip made by a company. I don't know what happened with this model. It is supposed to be some 85mm in width. However, in onshape, it is in the thousands of millimeters. It exports at 1/2 a GB currently. "Just scale it?" you may say. Welp, I tried that and the exported model is broken when imported into a slicer. I don't recall how I was able to scale it - once - last year for 3D printing. It has been awhile. But I did manage to and made one for testing. It is a really fun and functional slingshot!
I want to share it with others for free. However, I can't get a sound export to do so. For example, Cura will say to fix the model. I don't know what to do here. Even the model I managed to scale fails on other people's computers and or software. If anyone is interested in helping with this please let me know! I'm glad to share editing permissions for the document etc. I just want to share this model freely with other who like to shoot slingshots.
Thank you!
See the distance between points over there ——>
  • glen_dewsburyglen_dewsbury Member Posts: 1,124 PRO
    No wonder you're playing with scaling. The values were started in meters instead of millimeters. There is no need to scale individual parts and sketches. The parts can be group selected for scaling with out the sketches. Or start fresh with units set in mm.
  • david_no_thanksdavid_no_thanks Member Posts: 8 ✭✭
    edited March 2
    Yes. It was an oversight to say the least. I don't know how to correct it.
    Sorry, but I do not follow your suggestion here.
    I tried to scale them as parts - if that is what you mean. I think it took about 10+ scale events in the left pane to get them as small as desired. With scaled as such, I had a broken export STL. Maybe I'm not doing that right. Something seemed off. 10+ events?
    "Or start fresh with units set" This is not an option for me. I am not willing to do it all over again.
    In here transform 10 scales all the parts at once.
    See Part Studio 2. A fresh start that took a few minutes(about 15 minutes and a cup of tea) with no scaling. Way faster then trying to fix what was there.
    https://cad.onshape.com/documents/b130ca963931bb0c1bdd7c6d/w/0e818b99d456dac88bfd171f/e/4c576b0784650ef08d005a7e
    The learning center (although it may take a while) is still faster than speculating your way through. Still come back and ask questions. Lots of folks glad to help out.
    https://learn.onshape.com/
    I'm not that good. This took me hours over days,
    You're close but no cigar. I appreciate you doing all of that. But many details are missing. The angle of the aim points. The band pull over that and creates a sight as the band forms around when drawn. The center shape is not right. The curves between arms are not unique and the pinky hole size is too large. Also, missing the pieces that go in the holes to hold the bands.
    That stuff all matters. For me, this was rather a free handed sketch. And it was magical that it just happened to feel so good in the hand. I'm rather all in with this model.
  • Ste_WilsonSte_Wilson Member Posts: 503 EDU
    edited March 5
    @david_no_thanks you can look at and copy @glen_dewsbury 's model and add/ change those things, either edit his sketch or add/ remove from there. Looking at the sketch/ link you have provided I can't see what else Glen could do. That IS your model, or the start of it at least, tweaked.
    It really would be worth your time doing the learning center stuff.
    Hi Dave. My version was an approximation to achieve the look. I left out some dimensions purposely for you to finish since they were not hard dimensioned in your sketch. Instead I was going for method. Note only 3 features in the list and all can be fixed as you see fit.
    I would prefer to use and scale the original model. I'm picky I guess :D But there is a hand-feel that I think matters.
    I can provide stl, step files or anything needed, if anyone wants to give it a shot. I think I used MeshMixer previously to scale. But that failed in some slicer software. I am also willing to offer editing permissions for the document, but I don't know how to share it like that atm.
  • MDesignMDesign Member Posts: 1,018 ✭✭✭
    there's a share button at the top that will prompt you to change permissions as needed.then copy paste the link. Feel free to dm me a zipped version of the stl if you want.
    I appreciate that. Your time and effort.
