Straight loft
uldemauldema Member Posts: 14 EDU
I need a loft from plane 1 to plane 2 going in a straight line, sort of, the middle section is a bit smaller at the top. I have tried every possible combination of loft setting that I can think of but for some reason I always get this forced curve in the part where the line should just go straight up. I wonder if Loft is the way to go here, I have also tried to Extrude it but then I cannot get it to connect. Is there a non-curved loft somewhere?
https://cad.onshape.com/documents/10da032b16c0fc09bfebb379/w/39d7ae82c85ab169fca62c97/e/27efb87b412ca871ff855c10?renderMode=0&uiState=67c810df58985b016001689b
  • robert_scott_jr_robert_scott_jr_ Member Posts: 577 ✭✭✭
    Hello. That URL you posted does not lead to your document. - Scotty
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 624
    Have you tried using the Connections option?
  • john_lopez363john_lopez363 Member Posts: 123 ✭✭✭
    @uldema ..almost certain the issue lies in your sketches…. From the pic posted it's apperant the bottom sketch has an extra line segment to it. Make sure your sketches have the SAME number of points (bottom sketch has the same number of points as the top sketch), then Loft will behave properly.
  • uldemauldema Member Posts: 14 EDU
    I don't understand what is wrong with the link, I used the Share button and for me it links to the document, I don't know how else to share it.
    I have tried the connections, thank you, in the end I've fixed it in the Sketch as @john_lopez363 said in his reply.
    edited March 6
    @john_lopez363 Thank you, it was indeed a difference in points due to a construction line I used in one sketch and not in the other.
