cPlane Line at Angle to edge
graham_lockgraham_lock Member Posts: 249 PRO
Hi,
I want to create a plane at angle to a reference edge.
When I reference the edge in cPlane as the entity it cannot determine the rotation axis, so I'm now experimenting with creating a sketch line along that edge and passing the sketch line to cPlane.
The below code doesn't work - how should I pass the line to cPlane or is there a better way to do this?
var sketchSpacer1 = newSketchOnPlane(context, id + "sketchEdgeLine", {
"sketchPlane" : sketchPlane1
    skLineSegment(sketchSpacer1, "sketchEdgeLine", {
            "start" : startPoint1,
            "end" : endPoint1
    skSolve(sketchSpacer1);
   cPlane(context, id + "planeAtAngle", {
        "entities" : qSketchRegion(id + "sketchEdgeLine"),
        "cplaneType" : CPlaneType.LINE_ANGLE,
        "offset" : 0 * millimeter,
        "angle" : 0 * degree,
        "oppositeDirection" : false,
        "flipAlignment" : false,
        "flipNormal" : false
I've also tried using qCreatedBy for the entities but to no avail.
Any help appreciated.
Thank you.
