How to remove an part studio insert
jake_gelhard
Member Posts: 16 PRO
Hello, I have been working on a assembly for awhile now and I accidently inserted a new part studio into the assembly. I have been trying to figure out a way to delete this insert but I cant seem to find a way. I have used the Hidden feature on it for now, but because of this mistake, the drawings I have are also now messed up. So is there anyway I can remove this part studio from my assembly.
Thanks.
Perhaps I'm misunderstanding your issue, but can't you just right-click it from the instances list and select "Delete?"
Im not sure, there is no promt to click delete, Its almost like the part is combined now with everything. Would a link to the file help?
Yes, a link to the document would help. You'll have to make it public for others to be able to actually make their own copy to look at.
Here is a link to the document. the tab for this assembly is the "RMD V2 with Lid"
https://cad.onshape.com/documents/ba107bd8e44eccd7eea1408d/w/9922844164f699390f7377ac/e/1cbb27f7696c64a6fea93ad9?renderMode=0&uiState=67c85306c68e425f082f0bfd
Thank you
It's Assembly 2, inside the Reference Enclosure.
Oh ok, I did not see this. My issue now is how do I remove this assembly as there is no option on my list to delete it.
I think you'll have to switch to the Reference Enclosure assembly and delete it from there.
You were correct, thank you for all the help
