Select Other on ipad
Hi, I'm using my ipad pro with a keyboard, the Onshape application and a mouse. I have two lines in a sketch - one on top of the other - and I want to select 'the other line'. I have tried pressing the ` key, the @ key and frankly, i've tried every single other key on the keyboard.
I've also tried right clicking, centre button clicking, the apple pencil, my finger and probably my nose.
Any idea how to 'select other' on the ipad?
  • MichaelPascoeMichaelPascoe Member Posts: 2,822 PRO
    If it isn't available in the right click menu, it may not be an option yet. I tried it on Android just to see, no luck.
    You could change the view mode to translucent which will let you pick edges and vertices beyond your part. But this wont help if your trying to select an entire part or a face.
    RENDERCAD
