Select chain of sketch entities / Select closed loop
joshua_lee840
Member Posts: 6 ✭✭
Hello:
I want to select the highlighted sketch lines pictured below so I can convert them to non-construction lines (with the hotkey Q). In SOLIDWORKs, you could right-click any line segment and choose "Select Chain", which would highlight all the attached sketch entities. I had to manually hunt and peck each line to get this selection; is there a faster way to select all sketch entities of a closed loop?
2
Onshape team, I'd love to see more work around this, for example perhaps icons instead of dropdowns (similar to s-menu), and auto-selecting "faces" or "edges" based on right clicking an entity
I've added this as a feature request you can vote for here: https://forum.onshape.com/discussion/27101
I voted for it
