GeometryType.SURFACE error
Hello,
I was trying to implement a function to select a gore created by a loft, and i wanted the user to select the different gores to add an offset surface. But when I add the GeometryType.OTHER_SURFACE, I have this error.
I heard about using qGeometry but I don't know how to use it and when.
If someone can help me, thank you.
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 373 image
    You can make a query for the lofted walls:
    const qLoftedWalls = qGeometry(qOwnedByBody(definition.selectedBody, EntityType.FACE), GeometryType.OTHER_SURFACE);
    But this is not in the precondition of the feature… in my example the definition.selectedBody was just the query for a EntityType.BODY, but it could already be a query in your code.
