Revolve
chandrashekar_rchandrashekar_r Member Posts: 46
Hi
Not able to understand how the revolve sketch is drawn can someone provide me detaield steps done here for revolve potion of sketch
https://cad.onshape.com/documents/e9cdfa45da57bfd55e3b3dad/w/b5024d90bb177d4570365061/e/1aef2078620e3b8449417a03?renderMode=0&uiState=67ceb7f3668a6a59b714539a
  • MDesignMDesign Member Posts: 853 ✭✭✭
    edited March 10
    click here for Learning Center Revolve
  • chandrashekar_rchandrashekar_r Member Posts: 46
    Hi
    I did try but unable to get it requesting kindly help as it is crucial help in my school project please
    It's not clear what you've tried and been unsuccessful at. The link you provided has a revolve in it. I am unable to provide any further help unless you provide more detail on how you've not been able to do a revolve.
    I am trying o replciate the skecth in this
    https://cad.onshape.com/documents/d6030820f3f6552ce3f63f8c/w/4f911676f05f0f80a567b8c5/e/9b55d21ec09737bdc415a925?renderMode=0&uiState=67cfb3a5b23cd13a42a54817
  • jelte_steur814jelte_steur814 Member Posts: 485 PRO
    still not very clear.
    but when you open the sketch and check 'show constraints' it shows that the lines creating the portion you'r cutting out in Extrude 1 are constrained horizontally and vertically.
    remove a constraint, add an angular dimension and that may be what you're looking for
    like MDesign said, this is very basic stuff so I support his recommendation to spend more time practicing and training in the learning centre.
