How to make the transition from a chamfered edge to an unchamfered edge?
fred_wildfred_wild Member Posts: 29
I'm modeling a porch column in Onshape. The top and bottom parts are square in cross-section, extruded from separate planes. The middle part is an octagon in cross-section (basically a deeply-chamfered square), extruded from a separate plane. Between the parts are short transitions where the octagon becomes square, where the chamfer tapers to nothing. My attempts to loft the transition failed. Is there a way to diminish a chamfer along an edge or otherwise transition from an octagon to a square? Thank you.
Fred Wild
Porch Deck | Column
