Inserting imported PNG into sketch
graham_lockgraham_lock Member Posts: 249 PRO
edited March 12 in Community Support
Hi,
I'm having problems importing a PNG file into a sketch - it renders as a dark grey rectangle.
When the file is viewed in its browser tab it's fine.
Not a show stopper because JPG imports work but it would be good to understand the problem.
My test document is here:
https://cad.onshape.com/documents/a1c8e7396701ea7cc181e411/w/f75c7eee688d240a89becb00/e/f45a866919271bcd601ca3da
Any thoughts appreciated.
Thank you.
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 320
    The max image size allowed in sketch background will be GPU dependent, and you can check yours out here: https://webglreport.com/
    In my case I have (MacBook Pro M1)
    Indeed by resizing your PNG to be width = 16384 it works fine as a sketch background.
  • jelte_steur814jelte_steur814 Member Posts: 495 PRO
    this may be worth a support call for a bug report. beats me anyway
  • MDesignMDesign Member Posts: 932 ✭✭✭
    You must be hitting some kind of max resolution or file size with that… resizing it to 90% allows it to work. your jpg is much smaller resolution.
  • graham_lockgraham_lock Member Posts: 249 PRO
    Thank you all for your replies.
    @GregBrown - I have an NVIDIA GeForce RTX 4080 and the textures report is identical to your MacBook.
