Derived function no update part after change configuration in orginal
pawel_wojewoda692pawel_wojewoda692 Member Posts: 3
I have part studio 1 where i create part 1. It is configured by configurations in two ways. 1st i create plane (line angle) where in configurations i can change angle of this plane. Than on this plane i have 3 sketches. I have configuration where i change sketch to extrude function. This extrude create part 1. (form oval, box and triangle sketch). Then in second part studio i use derived function. Where i change configurations in 1st part updates but no in derived second part studio.
  • S1monS1mon Member Posts: 4,061 PRO
    When you derive, you pick a configuration. In fact, if you choose to derive a version within the same document, or derive from another document, you have to pick a version. In this way, updates to versions or configurations are a PULL process not a PUSH process.
