Improvements to Onshape - March 13th, 2025
Roy_MutalikRoy_Mutalik Member, Onshape Employees Posts: 39
edited April 4 in New in Onshape
With our fourth release of 2025, we've got some wonderful improvements in a variety of different areas. Let's have a look.
CAD IMPROVEMENTS
COSMETIC THREADS (3D)
When defining a thread using the Hole feature, or External thread feature, cosmetic threads are rendered on-screen in the modeling environment.
https://onshape.wistia.com/medias/nqk2m03p1e?embedType=web_component&seo=true&videoWidth=960
ROUTING CURVE
The new Routing curve feature assists with many 3D curve workflows including wire, tube, and pipe routing
https://onshape.wistia.com/medias/tprjlr63ka
CONSTRAINED SURFACE
The new Constrained surface feature allows you to create a surface fit through a series of selected points or defined entirely by a mesh.
https://onshape.wistia.com/medias/k3cr55vqev?embedType=web_component&seo=true&videoWidth=960
MOVE BOUNDARY - UP TO WITH OFFSET
The Move boundary feature now allows for an Offset distance to be defined when using any of the "Up to" end conditions.
https://onshape.wistia.com/medias/fjsk5hmoss?embedType=web_component&seo=true&videoWidth=960
FRAMES - LOCK PROFILE FACES
The new Lock profile faces option in the Frames feature allows you to lock your frame profile to follow one or more selected faces. This allows you to correctly introduce twist in your frame elements, to accurately follow non-planar curves.
https://onshape.wistia.com/medias/cp1qchnxll?embedType=web_component&seo=true&videoWidth=960
ASSEMBLY SUBFOLDERS
You may now nest folders in the Assembly Instances list, to create assembly subfolders.
https://onshape.wistia.com/medias/uwgnlybric?embedType=web_component&seo=true&videoWidth=960
EXPAND/COLLAPSE ALL FEATURE FOLDERS
You may now expand or collapse all feature folders in the Part studio Features list and Assembly Instances list in a single click.
https://onshape.wistia.com/medias/fx4rf1ism9?embedType=web_component&seo=true&videoWidth=960
EXPORT TO RHINO - SELECT VERSION
When exporting to a .3dm file for Rhino, you can now select what file version to create.
https://onshape.wistia.com/medias/gfgludz7ad?embedType=web_component&seo=true&videoWidth=960
DRAWINGS IMPROVEMENTS
DIMENSION THREADS
You can now directly dimension threads on your Onshape drawings using the Dimension tool.
https://onshape.wistia.com/medias/v5sn11sj4x
RENDER STUDIO IMPROVEMENTS
ADD TEXTURE TO APPEARANCE - IMPROVED WORKFLOW
The process for applying a custom texture to an appearance has been greatly improved. You may now directly add a bitmap image by right-clicking on an applicable Appearance panel parameter and selecting Use bitmap file from the context menu.
https://onshape.wistia.com/medias/f1to5222tc?embedType=web_component&seo=true&videoWidth=960
LINK TO PART STUDIO APPEARANCE
A new Appearances list context menu option, Link to Part Studio Appearance, is available. This removes the applied Render Studio appearance, and instead re-link the entity to the original Part Studio appearance.
https://onshape.wistia.com/medias/skkqaaieu7?embedType=web_component&seo=true&videoWidth=960
«13
  • S1monS1mon Member Posts: 3,378 PRO
    Well isn't this a very pleasant surprise! Released on a Thursday instead of Friday, and a bunch of things that many people have been asking for for a long time.
    Routing curve we've had many previews for, but great to see it in production now. Still looking forward to a more generalized 3D spline tool, but happy to have routing tools.
    The constrained surface tool is beyond what I had seen in Plasticity. More reverse engineering tools are very welcome.
    The cosmetic thread appearance will make threading a lot easier to understand on unfamiliar parts. And the ability to dimension them in a variety of ways on 2D drawings is very welcome.
    One of the biggest quality of life things for me is the ability to collapse and expand all folders with a menu click (and presumably a keyboard shortcut).
    Nice to see RenderStudio getting some basic quality of life improvements as well.
  • Nick_HolzemNick_Holzem Member Posts: 147 PRO
    Woah! Most all will immediately be beneficial for my line of work. Nice one Onshape, and a day early even. 🤩
    I imagine you know more details about this, but I didn't see any mention of the triad manipulator improvement other than this post. It's not in the changelog. Maybe that was an oversight on Onshape's part?
  • MichaelPascoeMichaelPascoe Member Posts: 2,429 PRO
    @S1mon Oops, that was from a previous change log that I missed. Still super excited for that!
  • STEGSTEG Member, User Group Leader Posts: 124 PRO
    It is crazy how these small improvements will make my life easier as a mechanical designer! 👏
    I can't pass over in silence the new cosmetic threads… 🏆️
  • glen_dewsburyglen_dewsbury Member Posts: 1,083 PRO
    edited March 14
    I think is a very useful update. Especially the constrained surface to replace mesh imports to something way more useful. 😋
  • GregBrownGregBrown Member, Onshape Employees, csevp, pcbaevp Posts: 322
    The new manipulator has been in FeatureScript for a little while, and is documented https://cad.onshape.com/FsDoc/library.html#module-manipulator.fs
    It's called a fullTriadManipulator and there's a parameter on it displayEditView that determines whether you'll see those text boxes
  • zachary3352zachary3352 Member Posts: 3 ✭✭
    Huge update! Awesome work, Onshape team! I'm looking forward to using many of these features on future projects.
  • MDesignMDesign Member Posts: 946 ✭✭✭
    @GregBrown @EvanReese Thank you. Constrained Surface is the bees knees, the cat's meow, and all that and a bag of chips. Did not expect to see that quite this quickly. That is a huge time saver and nearly exactly what I had hoped for from such a feature. One additional tweak would put it over the top. and That is extend the capability to create a perfectly flat surface via a calculated median of point deviations. Just a simple check box or a 3rd tab would suffice.
    This tool is going to be crazy useful to many users and save sooooo much time of creating planes, sketches, curves and trial and error. WELL DONE! Move boundary with offset is a nice complimentary tool as well.
    Oh good job on the other stuff too. ha
    You can consider this IR complete.
  • Michael_SideratosMichael_Sideratos Member Posts: 1 PRO
    DAMN!!,I 've missed the 3D routing curve by A DAY. From now on all my work will get SO MUCH EASIER!!!!
  • robert_stilesrobert_stiles Member Posts: 129 PRO
    edited March 14
    Any one else tried opening the configuration tab following this update?
    Its empty for us, but only in some documents? I will raise a bug report, but if any one else has issues please reply
  • graeme_andersongraeme_anderson Member Posts: 11 PRO
    Did the selection issue with the Snapdragon X Elite - X1E80100 get resolved in this update? Didn't see it in the changelog.
    https://forum.onshape.com/discussion/comment/109877#Comment_109877
  • martin_kopplowmartin_kopplow Member Posts: 836 PRO
    This time, I find it hard to even name a favourite! It appears all of the improvements will be immediately useful. I have certainly been running into trouble not having them available before, and I can tick some off my wish list now.
    Great one! :0)
  • SieciehSiecieh Member Posts: 2 ✭✭
    🙏 W O W
  • Henk_de_VlaamHenk_de_Vlaam Member, Developers Posts: 256 ✭✭✭
    edited March 14
    Sorry, but the cosmetics look right-handed to me.
    Henk de Vlaam (NL)
  • Stuart_Wood_01Stuart_Wood_01 Member, csevp Posts: 9
    Fantastic !
    Thanks Onshape :-)
  • don_williams909don_williams909 Member Posts: 146 PRO
    Holy Moley! Lots of cool stuff here!
    FYI they have identified a bug here, its getting fixed. That is of course the down side of regular updates, especially when you have built a lot of specialist bespoke stuff under the bonnet… As much as I love the regular updates, every now and again they make something fall over that was working before.
    It appears a few of my documents with configurated features have only been partially or failed the automatic update process. I have expand/collapse (which is awesome!!) but I am missing cosmetic threads, constrain surface, move boundary, routing curve.. the majority of the update. Will the remaining features be pushed once this bug is fixed?
    Caden,
    Do you make the CF Public?
    And… do you mean Pitch instead of Thread?
    Henk de Vlaam (NL)
  • john_allen289john_allen289 Member Posts: 40 PRO
    Excellent as always Onshape - constrained surface let's us make another third party piece of expensive software redundant! Great job.
  • EvanEvan Onshape Employees Posts: 65
    Yes - we believe we've resolved the selection issues on the Snapdragon X Elite GPUs. Please let us know if you find the issue is not resolved.
