Filling the space between two curved surfaces
andrew_wilkins603andrew_wilkins603 Member Posts: 2 EDU
I have a student who is trying to fill the space between the threads and the tapered surface in this model and then continue the threads to the end of the "screw" in a loft so that it comes to a point. Any help would be greatly appreciated.
https://noblesville.onshape.com/documents/e361c61352d39471827f1010/w/661402b826e1cf6e939bcb2d/e/6a33a9a4611ed897500afb1b?renderMode=0&uiState=67d8414df07d355b6308d585
  • eric_pestyeric_pesty Member Posts: 2,104 PRO
    Try delete or replace face
  • martin_kopplowmartin_kopplow Member Posts: 726 PRO
    Create the thread on the centerline rather than on the shaft surface. That'd eliminate the issue right from the beginning.
