How to cut a big part into printable smaller parts
Hi,
so I have this "frame" (1230mm x 1085mm), which is way to big to be 3D printed at once. What is the best way to cut it in printable parts with some kind of dovetails to assamble it later on?
https://cad.onshape.com/documents/888f5b799301d084acc6644f/w/915d658d3adae8880e788d56/e/b0fab4e2b2b0841653fa3430?renderMode=0&uiState=67dbf5e4d3499679a577b753
Thanks a lot for your help!
  • MDesignMDesign Member Posts: 1,348 PRO
    You can put in a sketch of where you want joints and the shape of them via a single chain of lines for each joint. then extrude a thin remove to give some tolerance. then pattern the feature as needed.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 953 PRO
  • roman_rennhoferroman_rennhofer Member Posts: 6
    Thanks for your reply!
    But this feature already needs more than one part, right? Or am I doing something wrong?
