How to cut a big part into printable smaller parts
roman_rennhofer
Member Posts: 6 ✭
Hi,
so I have this "frame" (1230mm x 1085mm), which is way to big to be 3D printed at once. What is the best way to cut it in printable parts with some kind of dovetails to assamble it later on?
Thanks a lot for your help!
MDesign
Member Posts: 1,265 PRO
You can put in a sketch of where you want joints and the shape of them via a single chain of lines for each joint. then extrude a thin remove to give some tolerance. then pattern the feature as needed.
1
Box Joint
Thanks for your reply!
But this feature already needs more than one part, right? Or am I doing something wrong?
