How can you wrap/ project a pattern onto an irregular lofted surface? Is it possible?
I have a model that I created with a loft and have it both has a solid and a surface. I am trying to wrap a pattern/text around it to give it some character. I know wraps only work with cylindrical surfaces, so how do I add texture to this surface? Can this be done in Onshape, or should I use something like Blender/ZBrush?
  • jelte_steur_infojelte_steur_info Member Posts: 648 PRO
    in modeling, wrap and decall are only available for cylindrical and conical shapes i believe.
    you could project (sketch) curves onto the lofted face. I doubt that's what you're looking for, but it's possible.
  • wayne_sauderwayne_sauder Member, csevp Posts: 641 PRO
  • EvanReeseEvanReese Member, Mentor Posts: 2,826 PRO
    @andy_miller859 Attractor Pattern is what I usually reach for (since I wrote it), but the Texture feature by @MichaelPascoe is also good at this kind of thing.
    However a lot depends on the kind of texture you want. If it's geometric, and fairly coarse (like a hexagon pattern), these custom features are good. If you want something organic, like leather, or super fine, like tiny bumps, then Blender, zBrush, or some other mesh-centric modeler will be better.
  • andy_miller859andy_miller859 Member Posts: 4
    The Attractor Pattern did exactly what I needed. Thank you!!
