OMG! Section View is awesome!
jeff_mcafferjeff_mcaffer Member Posts: 88 ✭✭✭
I've been using OnShape as a hobbyist for a while now and for whatever reason only just discovered Section View. See Tech Tip: How to Use 3D Section Views in Onshape
If you are designing anything moderately complex or that has internal structure this is the bomb. Previously I'd mess around making things transparent or hiding things either when working on the parts or showing people the design. Forget all that. Just section it. So, if you don't know about this, check it out. If you do, why didn't you tell me?!
Thanks OnShape team
  • MDesignMDesign Member Posts: 911 ✭✭✭
    You probably didn't ask. 🤪
