Split part - What determines which side is which?
Andre_ComellaAndre_Comella Member Posts: 71 PRO
When using the Split feature to split a part, I get two parts, great. But one of these parts seems to have the same "identity" as the original, and the other is "new". What determines which side of a split is the old part and which one is the new? Can I control it?
My main reason for asking is that inserting a split into the middle of a feature tree can cause errors when downstream features reference the wrong body
  • kees_bijkerkees_bijker Member Posts: 170 ✭✭
    I don't understand how you get one identical and one new? In my case there will be two identical parts with the same name.
    Also it does not matter at all how I start the split so I cannot see how to influence which part is the original and which is the additional.
    What I do straight after each split is to rename the parts logically to their function, so later on I cannot mistakingly address the wrong part.
    If your experience is different, i.e. you do get a new part with a different name, this is something I cannot check as my system is not behaving the same way. I would not know why it would be different to be honest with you.
  • jelte_steur814jelte_steur814 Member Posts: 527 PRO
    I know. This sucks.
    The best way to prevent that is to Transform-copy in place-. this way you ensure a new part is created.
    then split each of them without 'keep both sides'.
    One of the first custom features 'Split to new" i built was for this particular issue.
    So what is different to this "split to new" if in the standard split you rename the new parts immediately after the split?
    I have to say I never had any issue at all with doing it this way and unless I am missing something, I do not see any immediate problem!
    @kees_bijker if through changes earlier in the feature tree the splitting tool (surface or plane) changes direction, the newly split parts will change identity. and all features downstream will loose their references.
    With the split-to-new FS, this might still happen, but the 'opposite direction' button can be hit to repair it in one click.
    Ok, never had that happen yet but good to know I suppose. Its like in context design and nothing ever happens UNTIL that day you forgot it was in context and you do a transform on it and your whole assembly is up the creek 🤣
    There must be a ton of these troubles lurking inside onshape that you might never experience.
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,018 PRO
    It's not the part name. There is an internal "part/surface ID" that gets referenced by later features. It also comes up when doing merges. In that case, the part/surface you pick first in the dialog box gets its ID propagated throughout the rest of the parts/surfaces merged to it. So when doing merges, it's important to pay attention to the order of the picks. This is probably true in most cad programs.
  • andrew_kleinertandrew_kleinert Member Posts: 97 PRO
    An example:
    Step 1: Design a hand part called 'Hand'
    Step 2: Do a Split operation to split off a finger. Keep both sides. You now have two parts called 'Hand'
    Step 3: Rename the part that is a finger to 'Finger', and leave the rest as 'Hand'. That all looks good until you …
    Step4: … move the rollback bar before the Split operation, and there's a 50% chance your whole hand is now called 'Finger'. There is a similar problem if you change an appearance downstream and it has undesired consequences upstream.
    It would seem helpful if the direction operator was kept in split for "Keep both sides" to allow some control over this.
    Thanks for the tip for this workaround
