Help to create angled rim around entire shape
Petr_SimunekPetr_Simunek Member Posts: 4
Hi guys,
I have this (in black) and need to model the one in red. I will need to add some fillets in the corners, bt assumne I can do that later.
Can you point me in to right direction, video or something ?
thx
P
  • jelte_steur814jelte_steur814 Member Posts: 489 PRO
    is it precisely square?
    In that case it's best to only model 1/8th of the part. if you did model the whole, you could take a pizza slice out. (extrude intersect) 1/8th of the part.
    Add the triangular rim, extrude it. preferrably before the shell feature that you may have used. else hollow it out manually with another extrude
    then mirror and circular pattern to make it complete again…
  • martin_kopplowmartin_kopplow Member Posts: 808 PRO
    Yes, Jelte is right: In Onshape, as opposed to direct modeling systems, one of the magic things is we can go back in time and change the beginnings of our model, so we don't need to model on top of what we already have.
    https://cad.onshape.com/documents/2bac0ccd67232564daeafba0/w/f08358bfa6dcb15593a5d426/e/8fcfdb08fe2566942837fada?renderMode=3&uiState=67e3ca8a38042859843781c8This could be further enhanced by using a common variable for Wall Thickness and Move Face Offset, should that be design intent.
  • Petr_SimunekPetr_Simunek Member Posts: 4
    Thank you guys!
    Seeing how this is actually done… pricelles!
  • eric_pestyeric_pesty Member Posts: 2,203 PRO
    I usually use mirror extensively, however for a simple shape like this, a sweep on a square profile is a simpler way to get to the same result:
  • eldon_browneldon_brown Member Posts: 50 ✭✭
    This is how I would do it, using my Polypipe FS
    https://cad.onshape.com/documents/28e26d44be5a638ef8e6a64a/w/a37d455480f4bdd7c32ba9ce/e/f5627a22815a30d9e44c16b5?renderMode=0&uiState=67e45b4404b4270ad90e63a2
    —Eldonb
  • MichaelPascoeMichaelPascoe Member Posts: 2,348 PRO
    edited March 27
    The real question here, is why it's taking all our PRO users more than 3 features to do this 😉
    https://cad.onshape.com/documents/c4469b7086cad2b01f32d62a/w/2ab04e4a2e6deab95247c28d/e/0727db57411fc…
