Help to create angled rim around entire shape
Petr_Simunek
Member Posts: 4 ✭
is it precisely square?
In that case it's best to only model 1/8th of the part. if you did model the whole, you could take a pizza slice out. (extrude intersect) 1/8th of the part.
Add the triangular rim, extrude it. preferrably before the shell feature that you may have used. else hollow it out manually with another extrude
then mirror and circular pattern to make it complete again…
Yes, Jelte is right: In Onshape, as opposed to direct modeling systems, one of the magic things is we can go back in time and change the beginnings of our model, so we don't need to model on top of what we already have.
https://cad.onshape.com/documents/2bac0ccd67232564daeafba0/w/f08358bfa6dcb15593a5d426/e/8fcfdb08fe2566942837fada?renderMode=3&uiState=67e3ca8a38042859843781c8This could be further enhanced by using a common variable for Wall Thickness and Move Face Offset, should that be design intent.
Thank you guys!
Seeing how this is actually done… pricelles!
I usually use mirror extensively, however for a simple shape like this, a sweep on a square profile is a simpler way to get to the same result:
This is how I would do it, using my Polypipe FS
https://cad.onshape.com/documents/28e26d44be5a638ef8e6a64a/w/a37d455480f4bdd7c32ba9ce/e/f5627a22815a30d9e44c16b5?renderMode=0&uiState=67e45b4404b4270ad90e63a2
—Eldonb
The real question here, is why it's taking all our PRO users more than 3 features to do this 😉
https://cad.onshape.com/documents/c4469b7086cad2b01f32d62a/w/2ab04e4a2e6deab95247c28d/e/0727db57411fc…
RENDERCAD
