'Bulk Update' to a version - For drawings
ry_gbry_gb Member, csevp, pcbaevp Posts: 167 PRO
Does anyone know if this exists? I'm referencing versions of partss in my drawing views for my parts so that the overall document runs faster, but the problem now is that every time I version the document, all of my drawings need updating. It's about 12 main drawings (with more to come, so probably close to 50), so it's a lot of time wasted when I have to:
1. Click each drawing tab to activate it
2. Right-click, select Update linked document
3. Update the document.
4. Rinse, repeat.
Ramon Yip | glassboard.com
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,529 PRO
    To clarify what @S1mon is saying, there is no performance benefit to referencing versions for drawings (but there is for parts and assemblies, and especially with derived parts)…
    So the solution is to reference the workspace in drawings and this allows you to update all of them easily using the tip above.
  • S1monS1mon Member Posts: 3,917 PRO
    Drawings always are referencing a version, or micro-version. If you make changes to the parts, you have to update the drawing tab. You can update all the drawing tabs at once, with or without creating a new version.
  • ry_gbry_gb Member, csevp, pcbaevp Posts: 167 PRO
    edited March 2025
    That makes sense, but for some reason, if my drawings referenced the workspace, the whole document was really laggy, particularly when updating the main assembly BOM. Moving to referencing versions in the drawings seemed like it fixed the problem. Looks like the issue might be some issue somewhere else, then. I'll change my drawings to reference the workspace again and report back.
  • BLeeVNBLeeVN Member Posts: 19 PRO
    Onshape Helps explains this differently (See Link for Source):
    The performance while opening a drawing (and the document containing the drawing) is significantly faster when the drawing references either a version or a revision of a part.
    To reference a version or revision, right-click on the drawing tab and select Change to version. Then select a version (or revision) to change to.
    The increase in performance when using a version or revision is significant and still allows you to update the drawing to newer versions and revisions as they become available
    So this means that there's Pros and Cons to both approaches.
    A. Drawings reference a version/revision is good performance-wise, but creates a tedious workflow when you make changes to a part
    B. Drawings reference the workspace: updates quickly, but more costly performance-wise.
    Is that correct? It seems that when in scenario A, I can't use the yellow update button, but rather have to re-update the reference manually per drawing. That adds up when I have to do it across 20 drawings.
