How to use function autocomplete?
AJ_Ratkovich
Member Posts: 4 PRO
I am trying to write my own functions with feature script. I want to use autocomplete the way the standard onshape functions do. The problem is I can't get it to work. I've been copying what I see in the standard library with no luck:
Here's a dummy function with what I'm trying
export function dummyFunction(id is Id) returns array{
* @param id : @autocomplete `id + "dummy" (forum is doing weird formatting things when I include the closing ` but it's there in my code)
return [];
Which in theory should give me dummyFunction(id + "dummy") when I call it. But I keep getting just dummyFunction(id).
What am I doing wrong?
MichaelPascoe
Member Posts: 2,772 PRO
Here is one of Onshape's, try this format instead:
/** * Attach an attribute to one or several entities. Will overwrite any attribute previously set on the same entity * with the same name. * * @param definition {{ * @field entities {Query} : Entities to attach attribute to. Throws an error if the query resolves to nothing. * @field name {string} : The name of the attribute @autocomplete `"myName"` * @field attribute : The data to set. Can be any type. If `undefined` is provided, any existing attribute * will be unset (and this entity will no longer resolve in [qHasAttribute] and similar functions) * @autocomplete `"myValue"` * * Legacy unnamed attributes: * If name is not provided, adds an unnamed attribute to the entities. If more than one unnamed attribute * with the same type is set on any entity, throws an error. * }} */ export function setAttribute(context is Context, definition is map) precondition { definition.entities is Query; definition.name is string || definition.attribute != undefined; } { @setAttribute(context, definition); }
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴0
/** * Attach an attribute to one or several entities. Will overwrite any attribute previously set on the same entity * with the same name. * * @param definition {{ * @field entities {Query} : Entities to attach attribute to. Throws an error if the query resolves to nothing. * @field name {string} : The name of the attribute @autocomplete `"myName"` * @field attribute : The data to set. Can be any type. If `undefined` is provided, any existing attribute * will be unset (and this entity will no longer resolve in [qHasAttribute] and similar functions) * @autocomplete `"myValue"` * * Legacy unnamed attributes: * If name is not provided, adds an unnamed attribute to the entities. If more than one unnamed attribute * with the same type is set on any entity, throws an error. * }} */ export function setAttribute(context is Context, definition is map) precondition { definition.entities is Query; definition.name is string || definition.attribute != undefined; } { @setAttribute(context, definition); }Learn more about the Gospel of Christ ( Here )
Ah I see, the placement is different. Thanks!!
