Split fails and I don't see why
Hello,
I have smething that seems weird to me: in I can't get this split to work:
the document is here: https://cad.onshape.com/documents/b84993bfd4616049d5cec857/w/8720bc7db7e9a32fa111f2c1/e/c0bc29226f43f71a336aae3b
Any suggestion on what is wrong is velcome !
  • jelte_steur814jelte_steur814 Member Posts: 493 PRO
    @MDesign was right though:
    if you turn curvature color map on, there's something strange going on still. this 'fold' starts in the area where the split was going to be.
    i tried splitting with an offset plane and at an offset of 15 mm it starts working.
    try playing with Connections in the loft that creates it:
    the guide curves indeed also create a weird kink because they're not normal to profile/tangent to wing surface.
    so I unchecked those.
    works here:
    https://cad.onshape.com/documents/e920b19fd2804eb5de8a06f6/w/5650947d4be38681b2f03ad5/e/1946924e0d58f2949fc0d808?renderMode=0&tangentEdgeStyle=2&uiState=67e6cfdc009baa4e28b1eec4
  • MDesignMDesign Member Posts: 907 ✭✭✭
    Probably need to clean up this area of your part. smooth that out and it should help.
  • marchal_sebastienmarchal_sebastien Member Posts: 9
    Hello
    Thanks for the suggestion - I needed to clean that up anyway it is a wing after all. It did not fix the issue:
    If I use an orthogonal plane, it accept the split. With the one shown "SectionneurSaumon" nope. Still the same document - I will see if the issue arrise as soone as I angle the plane.
    I did clean that up and could not get the split to work. I think this is a bug. The failure occurs when the plan angle is to sharp.
    I replaced that with a removal extrude and it work - although this is time consuming.
    Thanks for the assistance anyway.
    It does feel buggy. Not sure who needs to know to confirm.
    I tried playing with connections. the issue is the end profile from the loft doesn't produce a nice surface transistion. If I redefine the sketch to be cleaner I can get the split to work but that seems like not the right thing to do.
    works here:
    thanks a lot
    to summarize my loft is badly formed. I will take care of that better using your inputs.
    Hello,
    I recreated the wing entirely in a new Part studio, and I used more Spline Guides to force a simpler shape. It works and I am happily splitting every where. Thanks for the support, and I extract from this that "true" loft shape needs to be trippled checked.
    Thanks again.
