how to fill a area with hex pattern the the base is not a plane.
glenn_pierceglenn_pierce Member Posts: 11 ✭✭
Hi I have a shape like
https://cad.onshape.com/documents/83fc9177226e6d55d6c0fa3a/w/92f20d318230c3988f0ca7d9/e/3fee3455e63d066b8b36ddb0?renderMode=0&uiState=67e972aaac75802d883cb165
I want to fill the base with concrete so want to put a sparse hex structure in there to keep the concrete in place and add a little strength. I have tried the feature script hexfill with no success. I guess because of the curved surfaces involved.
What is the best way to add a grid or hex structure in the hollow base ?
Thanks
  • shawn_crockershawn_crocker Member, OS Professional Posts: 900 PRO
    Maybe create a new solid part that fills the area and then use a slicing program for your printer that does a hex infill and apply the infill just to that filler part. I think prusia slicer has a 3d honeycomb infill.
  • glenn_pierceglenn_pierce Member Posts: 11 ✭✭
    Thanks I found
    https://cad.onshape.com/documents/d1489499c6bfdc52ce5cf32a/v/ad38f0d2b991ca76d7d66836/e/84868ed45db74407cfd7ad2b
    Which seems pretty awesome.
  • EvanReeseEvanReese Member, Mentor Posts: 2,468 ✭✭✭✭✭
