pins feature script - could someone check it?
maciek
OS Professional Posts: 35 PRO
Hi,
I made a simple featurescript which makes holes for pins. This code is based on another feature script, but after my modifications it doesn't work.
Can someone look at it? Thanks
https://cad.onshape.com/documents/7885d89fd6ec3627369211b5/w/2607ea11c0a7be49338866ec/e/378d4212adbdd68ac5b3ad02
You'll need to increment
i,probably at around line 109 or so? Just inserti+=1;But you'll also need remove the
"MaxNumberOfPicks" : 1in line 33 to make it work for multiple vertex selectionsThanks, it works
