Bug? How to drive sub assembly configuration variables (string)?
MichaelPascoeMichaelPascoe Member Posts: 2,818 PRO
edited March 2025 in General
From within a main assembly, I'm not able to drive sub-assembly or part studio configuration variables (string) with my main assembly configuration variables.
Is this a bug or has it just not been implemented yet?
It appears to work with length values but string / text values are unconfigurable.
https://cad.onshape.com/documents/1cc2eb3fe42d26db3c42c251/w/27d288b63105d3f2c08ab11d/e/9b5d22d3f37a09436f1…
RENDERCAD
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,255 image
    Yeah, we haven't implemented "convert to expression" for string parameters in assemblies yet. I am curious, do you have a real-world use case for this?
    edited March 2025
    Yes, we have a client that has a pretty large project with up to 4 levels of sub assemblies. I wanted to let them choose color themes for the different types of parts (Sheet metal, frames, accent 1, accent 2, main, etc... ) in the top level assembly.
    I can think of a number of useful cases for this:
    • Customizing physical text embossing. (Serial numbers, client name, etc..)
    • Controlling data live via variable studio json down through the sub assemblies. For example have a map containing standard materials and appearances for different categories of parts.
    • Setting colors of all downstream assemblies.
    RENDERCAD
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 846 PRO
    edited March 2025
    Same exact real world use case here but for colorway management. We have catalog components that clients are allowed to specify custom paint colors for and creating a new explicit table entry and SKU in a configuration window for every possible pantone paint color is not realistic nor what I would consider to be correct document control. We have a part studio level configuration variable driving a hex color code script which partially covers this use case but it does not propagate up the assembly levels. Numeric parameters pass correctly but this is a case where I need the text expression to be able to drive hex values from 0-F
    Global assembly level control over text embossing is another valuable use case for us as well.
    Thank you @MichaelPascoe and @Derek_Van_Allen_BD — this is helpful.
